Can I program Sonos Advanced to group and ungroup my Sonos speakers?
My Sonos Advanced Devices can directly issue group all speakers / ungroup all speakers, but I can’t find any rule programs to actuate these items. I tried custom commands as well as music control and they don’t seem to be there.
Is there any way to make this a rule based action, or are the rules not able to do this?
Thanks!
You could try Webcore, but Rule Machine should pick them up using a custom command, if they are on the command tab of the device.
Edit: I guess that is called a Custom Action now, I don't really use Rule Machine. So you used Set Variable -> Mode or File to Run -> Run Custom Action and it did not show up?
Yes. It gave me a lot of choices, ut Group and Ungroup were not there.
Success!
The Sonos app creates a device for most controls AND another for group command. That device has the proper commans and I got it to work!
