I've never seen this but I figured I would ask anyway.
Is it possible to have alternate text on the input button similar to the input command?
The way I understand the "command" implementation:
The command line of code will create a entry button/box named (below) "requestMeasRM"
And when and entry is made and the button clicked upon the method named "requestMeasRM" will be executed.
command "requestMeasRM", ["string"]
Alternately is there a way to create a "dead" command button? I realize a button with a do nothing method might work but I was hoping I could use spaces etc in this button.
I guess essentially is there a way to add a text block to the driver page and or an app page?
Applications have a way: The link below is to my Application code for Kasa devices. in the method "startPage", there is the following code (edited to simplify):
Drivers: There is no explicit nor easy way that I know of (I have tried some). The drivers do not support this type of text blocking. I do use a state to give users a warning on some of my drivers: I have not explored the limitations and issues with this. It is merely a work-> around and may not be good in the long-run.
state.WARNING = "<b>Quick Polling can have negative impact on the Hubitat " +
"Hub performance. If you encounter performance problems, try turning " +
"off quick polling.</b>"
