Can Hue White light bulbs change their color temperature?
If the light is listed at 2700k can't you change it to 5000k by moving a slider?
Not on the device page, but your can on a Dashboard if you choose the Color Bulb template as shown below.
Unless you mean somewhere else?
The question is, where is the 2700k "listed"?
on the box. I found my answer.
the ambiance branded bulbs can change there white color the Hue White ones are 2700k only,
This topic has been marked solved by the community and subsequently closed.
