Can Hubitat Control Control4 Lighting Via Google Home
I am a Control4 dealer and Control4 runs my entire house. Google home integrates perfectly. Is there a way to control everything I have in google home with Hubitat? I am going outside of Control4 because I want to customize on wall tablets to be more functional than Control4 will allow.
Both Google Home and Amazon Alexa have decided to not export any devices that have been imported into their systems...
They have determined for whatever reason that they are the only worthy interface for all your devices...
Ok thank you for your help.
It should be possible to create an integration directly with Control 4, however none of the Hubitat staff have access to any C4 equipment or API information in order to do so.
If you have (or get) the Generic TCP Driver
http://www.chowmainsoft.com/generic-tcp-command
You can then use Hubitat to send commands to your C4 system to initiate commands on C4.
This is exactly what I need. Thank you! Let me know if there is ever anything I can do for you.
