Camect
So far, very impressed with Camect. The UI feels like it was created by programmers, but i'm used to that with HE :slight_smile:
I've got 15 nest cams running through it currently and its people alerts are seemingly very accurate so far.
Their support through their forum is very responsive at this time too.
" * Camect has an experimental UI for integrations with home control systems. It allows you to be notified of detections that are occuring, and to embed the camera display in another dashboard, and to change the home mode under external control. So far, it has been used to implement an experimental integration with Home Assistant. See
https://github.com/camect/home-assistant-integration
What i'm missing is the ability to call the makerapi from it so that I can trigger things in HE.
