I would like to access the Arduino Nano IoT data that is on a Arduino IoT Cloud Dashboard through a call from Hubitat (i assuming an app - but not even sure of that). I have never programmed across system communication and honestly don't even know what my first problem is.
I have created the Arduino Client and Secret IDs.
How do I send that information to Arduino IoT Cloud?
Arduino States:
curl --request POST \
--url 'https://api2.arduino.cc/iot/v1/clients/token' \
--header 'content-type: application/x-www-form-urlencoded' \
--data 'grant_type=client_credentials' \
--data 'client_id=YOUR_CLIENT_ID' \
--data 'client_secret=YOUR_SECRET_ID' \
--data 'audience=https://api2.arduino.cc/iot'
looking to learn -- how to make this call and see that it returns something to indicate approved access and how (if i needed) to close the connection?
Will someone help me through this and/or point me to an example?
here's a code snippet:
def params = [
uri: "https://${tccSite()}/portal/${settings.thisdevice}",
headers: [
'Accept': '*/*', // */ comment
'DNT': '1',
'Cache': 'false',
'dataType': 'json',
'Accept-Encoding': 'plain',
'Cache-Control': 'max-age=0',
'Accept-Language': 'en-US,en,q=0.8',
'Connection': 'keep-alive',
'X-Requested-With': 'XMLHttpRequest',
'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36',
'Cookie': device.data.cookiess
timeout: 10
if (debugOutput) log.debug "sending getStatus request"
asynchttpGet("getStatusHandler", params)
def getStatusHandler(resp, data) {
if(resp.getStatus() == 200 || resp.getStatus() == 207) {
def setStatusResult = parseJson(resp.data)
if (debugOutput) {
log.debug "Request was successful, $resp.status"
log.debug "data = $setStatusResult"
Your --data will go either in "header" or in "body" (not shown) depending on the API.
There are a lot of examples on github if you search this Community for "weather" packages. They all do something similar. I picked my example because it shows cookies and jams a bunch of stuff into Header, not because you need to copy/paste it.
Thanks for that: I've been looking at a lot of examples. I've gotten to the point that I have received the information on my access_key. I'm having two more issues now.
- I'm not getting information out of the function call - tried many different things TempTxt = resp.data and def of TempTxt outside the function, passed as ...Login(TempTxt) and even return TempTxt. How do I get it out of the function.
and/or
- is it because this return information is 'x-www-form-urlencoded' vs 'json' which Arduino doesn't reply to.
I'm struggling but having fun trying...
responded with:
which goes on with ...mndjsk..","expires_in:300,"Token_type":"Bearer"}
