I am exploring Hubitat and would like to know whether there is an integration that would allow me to create programs that react to specific entries in (for instance) a Google calendar ?
An example would be =
IF I have a calendar event at 8 am, my bedroom lights go ON at 6:30 am, or something similar.
Yes via this community solution:
Requires API setup in the Google Console but once setup you create search triggers to match against events, tasks, and reminders. From there a child switch can toggle or you can run rule machine actions directly in the search trigger.
Thanks so much. That is helpful, I understand the Google API as I now use same with ISY994 hub.
