Caddx Alarm Panel False Alarm
I installed my hardwired and wireless Caddx alarm system over 20 years ago. Have never had a single false alarm... until today.
I have Caddx wireless smoke detectors connected to the alarm panel. Though I have not been home in almost a month, today, one (one out of two) of the smoke alarms was triggered. Neighbors verified there was no fire.
Any ideas as to why a smoke alarm would trigger? The smoke detector is 20 years old. The battery is probably low; don't know if that could be an issue. Any ideas or suggestions?
If the system is like mine, from another vendor of wireless kit, then that battery level is stringently monitored and advised if low (in order to meet some of the panel classifications). So let's put that aside.
Focusing on age, all sorts of stuff could creep into the equation after 20 years...heck, even something like a capacitor losing it. Not that I know if there's one onboard, I'm just saying.
Also, there's some very unique sensing components in smokes that very easily could be failing in sensitivity after 20 years....the dust buildup alone could be a factor.
Try giving it a good vacuuming/dusting, change the battery, then get your incense and test it....not full blow, just faint whiffs....see if you can easily trigger it or if it takes a good hit. In the meantime keep your eye out for what you can find to replace it with.
Thank you. Since I posted this, it has reported a fire 4 more times (total of 5 times in the last 6 hours). I am kind of thinking that if the sensor is going bad that it would just not report an actual fire. But in this case, there is no fire and it is reporting one. Hoping maybe dust or an insect may be causing it.
Most smoke detectors are only good for 10 years. It will clearly state that in the manual. The sensor will start to not be reliable.
So it gets worse. Just had a wireless flood detector activate. So 2 different wireless devices have now falsely activated. Maybe the wireless board in the alarm panel has a problem.
I'd be pretty surprised if failing wireless components in the panel were causing discrete alarms.
Time to start googling and AI searching this on the broader web, specifically with respect to Caddx wireless systems.
Not that this should be a factor given the sophisticated nature of how these systems communicate, but have you added anything to your property that broadcasts in the same frequency ballpark?
Agree with suggestion to vacuum and blow out the device. I do this yearly with all my smoke detectors because I had one scare the crap out of me one evening with a false alarm because a spider got in there and was building a nest.
