Have an odd issue and wonder if anyone has any ideas. I have an undercabinet light (strip LEDs) that is zigbee, and occasionally I’ll find it on in the morning.
It’s plugged into same outlet as my fridge, so I think the fridge might be drawing just a little too much occasionally and causing the light to default on. Or… the hub is doing some type of maintenance on zigbee mesh and turning it on? (There’s no logging indicating it was ever told to turn on). But house guest says it turned on right around the time of the cloud backup for my hub.
Light is a sylvania led strip light.
Any advice would be great. Sounds like it may have woke up my house guest, so would be good to find solution! Hub is a c-8 (non-pro) running latest HE.
I find this from time to time, same sylvania flex LED strip and other Sylvania Zigbee bulbs. The one time it was my Aqara Opple 6 button remote. When remote loses its pairing the top button acts as a super Zigbee shotgun blast "on" for every freaking Zigbee bulb. The many other times I have no explanation, logs & events are empty. Started when I moved to the C8 pro.
It might if Alexa sent the command through Hubitat. On the other hand, if Alexa is talking directly to your device, nothing will appear in the logs. I have been pulling my hair out with Alexa lately.
Sometimes, she works, sometimes not, on the same devices.
