C8pro migration from c8 Help
Just migrated from c8 to c8pro. All devices and automations came across but unable to control any devices. Also the iPhone mobile app still is connected to old c8. Any suggestions?
Also, zwave detail shows 0 nodes.
You used the migration backup and followed the migration instructions? That backup should have had all of your radio data in it, but it sounds like you lost all your radio data for connected devices.
I agree. Looking for a solution.
Did you follow these instructions?
At the very least, do a hub shutdown from the Settings menu. Unplug the hub, wait a few seconds (30s is more than enough) and power the hub back up.
Your phone app will probably be fixed by pointing the app to the existing device, but on the new hub. In the phone app, you can through the hamburger menu bottom right, then add or reconnect a hub.
