If you didn't do so already, you may want to create a case by visiting support.hubitat.com, as you've done in the past. But since you've reached out here, and already had a case on file, I went ahead and looked at your hub.
It appears that you are dealing with this problem: C-8 Hub's Z-Wave Failed Overnight - #3 by velvetfoot
