Performed the .131 update (from .130).
Upon reboot, Zigbee was offline. Pan ID: NULL
Pulled power, waited a few minutes and restarted.
Zigbee is back online, all working.
Posting just in case anyone else has a similar problem.
Can you confirm your hub model - C8?
Just as an aside, make sure you shut down you hub (Settings>Shutdown) before pulling power so you don't corrupt the database on your hub.
Zigbee offline after an update has not been a common issue for a while (at least as far as I've seen). Hopefully it will be a one-time thing for you.
Thought I did..
I just updated the title.
