I want to experiment with other antennas. Is the Z-Wave antenna the one closest to the USB jack?
Yep
Please do report your results, as this appears to be a hot topic.
Model, observed/measured changes. Even if it is negative or neutral, it will help the masses interested in fiddling with the antennas.
Are both supplied antenna resonant at both 900 and 2400 MHz I.e. the same?
Both are dual mode antenna.
Would guess since there is no physically viewable difference.
Now available from www.hubitat.com/store
Here's a dual mode one that looks like an enima.
https://www.fairviewmicrowave.com/dual-antenna-3-dbi-gain-nmo-mount-fm51om1022-p.aspx
