C8 Pro upgrade today; Sengled Bulbs no longer responding
Hello all, I upgraded to C8 Pro today. All of my rules are fine, however the several Sengled Element Color Plus I have associated with the hub are no longer responding to anything actions. Has anyone else had the same experience?
Sengled is known to have issues with the mesh... so I wouldn't be surprised if these bulbs are in an unresponsive state after an upgrade. Try factory resetting one of them, and then run pairing. It most likely will show as a device that is found and reconnected, falling right back into place where it should be. If so, you can do that with all the bulbs.
Totally agree. I have a lot of these bulbs but the Classic version.
As a beta tester I find on many occasions I have to re-pair a bulb or 2 after a reboot to a new version.
For the most part I find them stable IF you are not rebooting often. :wink:
I have 21 of the Sengled Classic in my mesh and have zero issues with any of them on any updates or reboots.
In response to the information I gt from this forum (thank you) I put one of my bulbs back into pairing mode and added it back to Hubitat. That did the trick and it seems to be working fine now.
I have two sengled (color plus) and never had an issue. Just like my ThirdReality ZL1, sometimes itll fix itself if you power off/on. YMMV
