I am getting awful support from Hubitat. I have two Hubitats in different houses. One has worked fine for over a year. One is brand new and freezes within an hour every time after I reboot. I followed every online post to try and diagnose but nothing fixes. I've contacted support and opened two warranty claims for 2.5 weeks and have not heard back from Hubitat. I can't find a phone number to call. It has to be a hardward problem because nothing else works and my other Hubitat is fine.
Tagging @support_team
I've tagged Hubitat Support for you. In the meantime, can you summarize key details about your hub that freezes including:
- Platform verion
- How is it connected to your LAN
- Devices connected to the hub and the protocol used (zwave/zigbee/LAN/cloud)
- A brief summary of the steps you have tried so far
Also, in the event you have not yet tried this, please perform a soft reset on your Hubitat.
Sorry to hear that. If you didn't do so already, please check the spam/junk folder. Our emails may have been misplaced. As of today, our support queue was current with no outstanding cases past 24 hours.
When it freezes, do local automations also stop, or is it just the web interface? Are you accessing the hub remotely via Remote Admin or from the local network?
If you'd like, you can message me the hub ID and I'd be more than happy to look for any clues in the engineering logs.
Nothing in spam/junk folder
I can access web interface even after it freezes, but the hub no longer controls any devices and automations no longer work. When I use the web interface and try to execute a command, the hub says command submitted but nothing actually happens with the device. After I reboot using web interface, everything works for about an hour then stops again. This happens both via local network and remote admin.
- 2.5.2.135 (although I have upgraded and downgraded to a few different versions and they all have the same issues)
- Ethernet cable
- Zwave - light switches, thermostats, door locks, sensors, outlet switches
- Unplugged and plugged back in, upgraded and downgraded SW revs a few times, many reboots via web interface
PM your hub ID to @bobbyD
Also, did you try this?
Thanks for sending the details. I checked your hub and it looks like is dropping off your network on the hour. I don't see any reasons to believe that you are dealing with a hardware malfunction at this point. I would check your network setup, especially conflicting static or reserved IP addresses.
I'll check when I'm home, but how can I communicate with it over the network if it dropped off the network? I have no problem connecting to the hub on the network. It just doesn't control the devices anymore.
Sounds to me like you might have an IP address conflict. How is you Hubitat hub configured for network? Are you using DHCP with a reservation for the hub on your router? What IP address is your hub using? I suggest logging into your router and checking for conflicting addresses on your other devices.
What does your ZWave look like?
I've confirmed there are no conflicting IP addresses.
I've confirmed no conflicting IP addresses
I don't understand the question. Zwave is enabled and I've confirmed every device has at least two connected nodes.
Could you describe your network setup in some detail?
- Is your hub connected directly to the router (brand/model) or through a switch (brand/model)?
- Are there other devices using jumbo frames on your ethernet network? Theoretically, this shouldn't matter for the C-8 Pro, but definitely does for older models. So it is worth looking into and disabling.
- How is the hub's IP address being assigned? Static assignment on the hub? Or DHCP reservation on the router?
- Have you tried switching network cables?
- Have you performed a soft reset yet? As described here: Soft Reset | Hubitat Documentation
- Have you tried restarting all your network gear? Specifically, router and whatever switch/AP the hub is connected to?
- connected directly via LAN to Orbi
- As near as I can tell, no jumbo frames on ethernet network. PC/laptops are all not configured for jumbo frames
- DHCP reservation on router. No static IPs
- yes
- Yes, on soft reset. Didn't solve the problem
- Have restarted all network gear multiple times over 2.5 weeks. Does not solve problem.
Have again manually confirmed there are no IP conflicts.
What about going to logs and looking at App Stats, Device Stats, and also looking for errors in the logs. Anything stand out? Any apps running all the time?
I would start by digging through all the options in the Logs menu and see if there is any clue as to what is going on.
I ran all the logs for today through my Claude session on this topic and there was nothing unexpected. I look at Device Stats and Apps Stats and nothing is using excessive bandwidth or memory.
I also restarted all the network gear again with powering off C-8 and that didn't fix it. I can always access the device locally and via Remote admin but it just won't control any devices after about an hour. I have confirmed that there are no IP conflicts. Since I can always access the hub, this makes sense. I reboot it via the web interface and it works for an hour and then stops. It continues to indicate that a command was submitted, but nothing actually happens.
I did a soft reset as well today and that didn't fix it.
Are your devices Z-wave, Matter, Zigbee, LAN? Or a mix? Brands and types of devices on the hub? (a general list is fine)
And when you say everything stops, do things like sensors stop reporting Current States if you look on the device settings page? What about something like a light switch, do Current States change but the device does not, or do Current States also not report any changes when you do something like manually turn the device on from the Settings page?
