C8-Pro ethernet problem
Hi,
I’m running version 2.5.0.143 on my Hubitat C8-Pro. So basically I'm rebuilding from scratch my network because my migration from C7 failed. Any ways, I was running my c8-Pro from ethernet cabe. I want to move my C8-pro closer to my devices to help on finding my devices, so I switch to Wi-fi and turned off my ethernet connection. Now I want to go back to ethernet and I don’t see how. If I just connect the cable nothing happens. If I look on my router, the DHCP did not gave an IP to my ethernet. I can only see the ip of the wi-fi. I change the cable, the port on the router, and nothing…. What am I doing wrong? How do I turn on the ethernet again? Any help would be appreciated. Thanks MB
Connect the ethernet cable. On the underside of the hub you will see a round hole out of all the square ones. Using a toothpick or similar, insert in round hole and press the network reset button and hold for 7 or 8 seconds. The hub will reboot and you should be on ethernet.
