[C8 Pro 2.4.0.151] Room Lighting Activator doesn't turn on
I have a Room Lighting app set up as a scene.
I pushed button 1 on the associated Room Lighting Activator Switch to activate it and it set the lights
When I look at the list of lights, everything seems to be set properly, but the "Switch" value for the room activator is off.
I'm wondering if there's some rounding error or minor RGB difference I'm missing--but the scene appears properly set for every device.
@bobbyD any ideas?
The device list in your first screenshot looks like it may be cut off -- is that the complete list?
Knowing that would help determine if the current scene truly matches (or not) as "Scene Set" WRT the Indicator.
In the future, it's much more helpful to post screenshots from a PC when trying to diagnose something, since mobile screenshots are so space-limited.
I only posted part of the long list, but ALL of the devices do match. It's a long enough list that it likely wouldn't easily fit on a single desktop screenshot.
The RL app shows "Active" at the top, also
Maybe a shot in the dark, but I would try deselecting the checkbox in the Off column for each device whose desired setting is just Off
I'm not sure I follow.
The "Off column"?
That second checkbox column must be Force then, so nevermind my suggestion.
