I created a simple rule (5.1) to trigger at a certain time if a virtual switch is on (required expression).
For some reason, it refuses to trigger at the variable time.
Also, the time is in a hub variable. I have that on a dashboard so I can edit it easily. But, when I enter 8:13pm and today's date in the "variable" on the dashboard, it gets stored in the hub variable settings as 9:13pm and in the scheduled task for the rule.
When it didn't trigger the rule properly, I adjusted it so the scheduled time was 20:17 and watched the logs.
When the time matched the time, the rule started to trigger--but then the trigger showed up as false. And the rule didn't run like it should have.
