C8 HomeKit Pairing Code for Home Assistant
Brand new Hubitat user. Just purchased the C8. Before I start adding devices to it, I wanted to add it to Home Assistant. The HomeKit Controller, Hubitat (Bridge) is Discovered in HA, but when I go to configure it, I have no Pairing Code. Most manufacturers put this on the bottom of the device, but now I am thinking it was on the Get Started card that came with the device...you know, the one I threw away after Getting Started was over...
Is there any way to find the code now? Or is there a standard Pairing Code for HomeKit and the Elevation?
Thank you!
The code is in the HomeKit Integration app under Apps in the hub's admin UI. Navigate to Apps, open HomeKit Integration (beta), and you'll find the QR code or numeric code for manual entry there. Note that you do need to have at least one device selected in the integration before this will appear.
There is no code on the hub itself; it is generated in the app and can/will change if you use the reset options in the app. And no need to worry that you missed anything on the card in the box! There is a QR code there, but that is just an easy way to get to the go.hubitat.com site to set up your new hub.
Ah, perfect! I wondered if it would be in there somewhere.
Thanks so much for the guidance and the quick response!
