Hi
Switches do not go on/off. Automations don't work.
Reboot helped for few moments, but then all failed again. Is my hub faulty or what can I do?
Cheers
Petteri
Platform version 2.4.3.137
Hi
Cheers
Petteri
Start here:
Nope. It has worked just fine for many years. There are no errors on rules.
Adding devices work, but hub doesn't. It drops devices etc
A possible reason:
Did someone (you or a neighbor perhaps) add a new wireless router or extender that is running on a channel that is interfering with the Zigbee channel? Have you tried changing the Zigbee channel? That was the big symptom I had before I figured out I needed to lock my router's 2.4G network on to channel 1 to keep it as far away from my Zigbee network's channel as possible. In my case, it was adding a network extender, not because I needed it for the size house I am in, but because I wanted to connect a device that did not have WiFi and I could connect it to the lan port on the extender. I removed the extender and my Zigbee network started behaving normally again.
I changed to channel 11 and removed that Air box. Seems ok for now. Any air box to recommend, that doesn't cost a fortune?
Damn... @kkossev nails it again! ![]()
