C8 Failed - need to Factory Default
Hi all,
I am new to the Habitat world.
I have a C8 and I am not sure why, but it has broken.
Symptoms:
  • Web interface gives the following in Chrome:
This page isn’t working
22.X.X.X didn’t send any data.
ERR_EMPTY_RESPONSE
  • This includes Port 8081
  • I can however access the app interface, but it doesn't seem to give me access to much
I suspect this happened after I followed a link to set a static IP address with 255.255.248.0 mask.
Anyway, now the unit is useless and I need to Factory Default the unit, but I can't seem to figure out how to do it.
Can someone help?
Network reset will reset it back to DHCP: Network Setup | Hubitat Documentation
Hold the button for 7-10 seconds and let go, LED will blink and then hub will reboot.
Best practice is to set a reserved IP on DHCP server (often the router) instead of static on the hub.
