C8 - 2.3.5.125 - INNR SP-222 UK plug issues
Need some advise/help pls. New to C8 Hubitat.
Trying to add INNR SP-222 UK smart socket, C8 finds the device, adds it to devices and then green led on unit stops flashing. Unit was auto-added as Generic Zigbee Outlet.
In devices, newly added unit. is present, however unable to control it from device page at all.
Device pairing info
Manufacturer: innr
Endpoint 01 application: 27
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0000,0003,0004,0005,0006,0008,0B05,1000,FC82
Endpoint 01 initialized: true
Endpoint 01 manufacturer: innr
Endpoint 01 model: SP 222
Endpoint 01 outClusters: 000A,0019
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
Endpoint F2 application: unknown
Endpoint F2 endpointId: F2
Endpoint F2 idAsInt: 242
Endpoint F2 initialized: true
Endpoint F2 manufacturer: unknown
Endpoint F2 model: unknown
Endpoint F2 outClusters: 0021
Endpoint F2 profileId: A1E0
Endpoint F2 stage: 4
and logs show as
dev:2122023-04-17 11:56:54.832 AMwarndescription logging is: true
dev:2122023-04-17 11:56:54.830 AMwarndebug logging is: false
dev:2122023-04-17 11:56:54.829 AMinfoupdated...
dev:2122023-04-17 11:55:47.216 AMwarnfinished options testing...
dev:2122023-04-17 11:55:46.896 AMwarnstarting options testing...
dev:2122023-04-17 11:55:44.886 AMinfoGeneric Zigbee Outlet was turned off [physical]
dev:2122023-04-17 11:55:44.833 AMdebugdescMap:[raw:2A9C0100060A00001000, dni:2A9C, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:2122023-04-17 11:55:44.664 AMinforeporting configuration for On/Off (cluster 0x0006) succeeded
dev:2122023-04-17 11:55:44.638 AMdebugdescMap:[raw:catchall: 0104 0006 01 01 0040 00 2A9C 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2A9C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:2122023-04-17 11:55:44.489 AMdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 2A9C 00 00 0000 00 00 0900, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2A9C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[09, 00]]
dev:2122023-04-17 11:55:44.051 AMdebugrefresh()
dev:2122023-04-17 11:55:39.616 AMdebugdescMap:[raw:catchall: 0000 0002 00 00 0040 00 2A9C 00 00 0000 00 00 820000, profileId:0000, clusterId:0002, clusterInt:2, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2A9C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[82, 00, 00]]
dev:2122023-04-17 11:55:38.763 AMwarnrunning configure in 5 seconds...
Prior to the above attempt, factory reset and tried it to a Tahoma controller, which paired and worked as expected. So the INNR unit does pair and work, however trying again above to C8, goes through the motion, but not functional.
Update: After reading some posts of pausing to migrate to C8 due to Zigbee issues, I have powered back up C7 after resetting the radio's, now the z-wave device (TKB) and zigbee (INNR) do pair upto C7 and works as intended,
So now have C8 and C7 in a hub mesh setup until C8 is sorted for UK.
