I have a device ("Master Bedroom Ceiling Fan Light") that is, maybe, 10 feet from my hub--doors are open between it and the hub and the walls are just standard drywall).
Yet, it often ends up routing halfway across the house and back--I was doing some packet viewing and it seems pretty odd. Note that, in the packet trace, it uses the decimal "30" number vs. the hex "1E" number.
At the moment of this details snapshot, it seems to think it can connect directly at 100Kbps--but, as you see, it is changing its mind a bit.
Most of my devices on the new C8 are connected directly, at 100Kbps--but this one is really odd. It will connect directly at 100Kbps for a moment then, for whatever reason, it decides to go to 9.6Kbps and on a circuitous route.
It's one of the Inovelli Red Series Dimmer switches (and in a 3-gang box with 2 other z-wave switches that seem to be more "well behaved").
There are a few folks here with some serious z-wave understanding--I figured maybe someone would understand what might be making this light so unhappy (from the packet trace, it appears that the "ACK" is being sent but not received???).
The packet tracer is rather close to the hub itself (a foot or 2 away, right below it) so it and the hub should be seeing the same things.
Maybe @bcopeland would have a thought on why that 30>127 ACK packet wasn't seemingly understood by the hub??
I'm not seeing this on all my Inovelli Red Series dimmers, either.
And, I'm not sure this is a "horrible issue" (it seems to work, but also seems to be less than ideal)--I'm mainly just wanting to learn about why this might be happening.
Thanks!
