C7 running 2.3.8.119 with Hub Login Security enabled.
I had "Hub UI SSL only" turned on. After I turned it off, logins stopped working on http://<my hub IP>. They still work fine on https://<my hub IP>.
Edit: When I try to log in on http://<my hub IP>, it redirects me back to the login screen with this URL:
/login?loginRedirect=%2F
@gopher.ny @bobbyD Any ideas?
yup... ssl cert has to take effect
It's the opposite. I turned it on without rebooting, worked fine. It doesn't work when I turn it off.
Same problem after rebooting.
Strange.... maybe @bobbyD or @gopher.ny can help but it should have worked.
The strangest part is that it suddenly started working again. I don't know what made it tick.
system
Closed
10
