@mike.maxwell some live logs to see if this helps in any way to fix the lock state issue:
Please let me know if I can assist in any other way.
Logs when unlock command is issued:
dev:5162020-10-08 17:03:29.876 debugskip cmd: NotificationReport(v1AlarmType:25, v1AlarmLevel:1, reserved:0, notificationStatus:0, notificationType:0, event:0, sequence:false, eventParametersLength:0, eventParameter:[])
dev:5162020-10-08 17:03:29.795 debugparse: zw device: 17, command: 7105, payload: 19 01 , isMulticast: false
dev:5162020-10-08 17:03:28.889 debugDoorLockOperationReport: DoorLockOperationReport(doorCondition:2, doorLockMode:0, insideDoorHandlesMode:0, lockTimeoutMinutes:254, lockTimeoutSeconds:254, outsideDoorHandlesMode:1)
dev:5162020-10-08 17:03:28.832 debugparse: zw device: 17, command: 6203, payload: 00 10 02 FE FE , isMulticast: false
Logs when lock command is issued:
dev:516 2020-10-08 17:03:47.607 debugskip cmd: NotificationReport(v1AlarmType:24, v1AlarmLevel:1, reserved:0, notificationStatus:0, notificationType:0, event:0, sequence:false, eventParametersLength:0, eventParameter:[])
dev:516 2020-10-08 17:03:47.602 debugparse: zw device: 17, command: 7105, payload: 18 01 , isMulticast: false
dev:516 2020-10-08 17:03:46.622 debugDoorLockOperationReport: DoorLockOperationReport(doorCondition:1, doorLockMode:255, insideDoorHandlesMode:0, lockTimeoutMinutes:0, lockTimeoutSeconds:0, outsideDoorHandlesMode:0)
dev:516 2020-10-08 17:03:46.617 debugparse: zw device: 17, command: 6203, payload: FF 00 01 00 00 , isMulticast: false
