C7 is unresponsive until unplug and reboot
Randomly, with no notable events, my C7 becomes unresponsive and the only way for it to become responsive again is to unplug and plug back in. When it becomes unresponsive, the web interface via the IP address is no longer working and the entire device appears to be locked up. This morning, it appears it was working up until 5:58am and I then had to reboot at around 6:20am. The log is below.
Do you have any insight into what may be causing this?
Andrew
app:412023-04-28 06:20:37.339 AMdebugchecking 3f6b4fc9-d0e2-4ca0-b60b-3ee8a28d8c13 vs 3f6b4fc9-d0e2-4ca0-b60b-3ee8a28d8c13 for in
app:412023-04-28 06:20:37.269 AMdebugselecting user device 41.94e0787e-e72c-4c19-a90e-f39939d745a4
app:412023-04-28 06:20:37.266 AMdebugwebhookEvent: Circle: dab8f474-7288-4e4a-8c8a-46a0074f3203, Place: 3f6b4fc9-d0e2-4ca0-b60b-3ee8a28d8c13, User: 94e0787e-e72c-4c19-a90e-f39939d745a4, Direction: in
app:412023-04-28 06:20:37.252 AMdebugwebhook event params: [access_token:2026d402-9fda-4144-877e-87f6904f75cc, safetimeout:1, userId:94e0787e-e72c-4c19-a90e-f39939d745a4, circleId:dab8f474-7288-4e4a-8c8a-46a0074f3203, placeId:3f6b4fc9-d0e2-4ca0-b60b-3ee8a28d8c13, direction:in] [body:userId=94e0787e-e72c-4c19-a90e-f39939d745a4&circleId=dab8f474-7288-4e4a-8c8a-46a0074f3203&placeId=3f6b4fc9-d0e2-4ca0-b60b-3ee8a28d8c13&direction=in, requestSource:cloud, HOST:cloud.hubitat.com, SCHEME:null, headers:[Accept:[/], X-forwarded-port:[443], Host:[cloud.hubitat.com], Cloudfront-viewer-asn:[14618], X-datadog-sampling-priority:[-1], User-agent:[curl/platform], X-datadog-trace-id:[8900782941225572754], Content-type:[application/x-www-form-urlencoded], X-forwarded-for:[52.23.104.203, 15.158.41.18], X-forwarded-proto:[https], X-datadog-parent-id:[9530758696244248104]]] null null
dev:362023-04-28 05:58:03.267 AMinfoMaster Bedroom Light was turned off
dev:362023-04-28 05:58:03.263 AMinfoMaster Bedroom Light was set to 0
dev:362023-04-28 05:58:03.256 AMdebugparse:zw device: 0C, command: 2603, payload: 00 00 05 , isMulticast: false
dev:3872023-04-28 05:56:57.757 AMinfoMaster Bathroom Can Lights was turned off
dev:3872023-04-28 05:56:57.749 AMinfoMaster Bathroom Can Lights was set to 0
dev:362023-04-28 05:53:57.476 AMinfoMaster Bedroom Light was turned on
dev:362023-04-28 05:53:57.472 AMinfoMaster Bedroom Light was set to 30
dev:362023-04-28 05:53:57.467 AMdebugparse:zw device: 0C, command: 2603, payload: 1E 1E 05 , isMulticast: false
dev:362023-04-28 05:53:57.286 AMdebugsetLevel(30, null)
dev:362023-04-28 05:53:52.169 AMinfoMaster Bedroom Light was turned on
dev:362023-04-28 05:53:52.162 AMinfoMaster Bedroom Light was set to 20
dev:362023-04-28 05:53:52.156 AMdebugparse:zw device: 0C, command: 2603, payload: 14 14 05 , isMulticast: false
dev:362023-04-28 05:53:51.961 AMdebugsetLevel(20, null)
dev:362023-04-28 05:53:46.031 AMinfoMaster Bedroom Light was turned on
dev:362023-04-28 05:53:46.026 AMinfoMaster Bedroom Light was set to 10
dev:362023-04-28 05:53:46.020 AMdebugparse:zw device: 0C, command: 2603, payload: 0A 0A 05 , isMulticast: false
dev:3872023-04-28 05:46:56.304 AMinfoMaster Bathroom Can Lights was turned on
dev:3872023-04-28 05:46:56.301 AMinfoMaster Bathroom Can Lights was set to 10
dev:3862023-04-28 05:46:51.302 AMinfoMaster Bathroom Vanity Light was turned on
dev:3862023-04-28 05:46:51.294 AMinfoMaster Bathroom Vanity Light was set to 10
dev:3882023-04-28 05:46:50.017 AMinfoBathroom Lights level was set to 10%
dev:3882023-04-28 05:46:50.006 AMinfoBathroom Lights switch was turned on
dev:3562023-04-28 05:45:31.828 AMinfoTemperature Sensor Sunroom: Temperature is 66.2°F
dev:1652023-04-28 05:45:21.719 AMerrorjava.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
dev:1642023-04-28 05:43:30.350 AMerrorjava.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
dev:1652023-04-28 05:41:30.540 AMerrorjava.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
dev:1652023-04-28 03:19:05.334 AMerrorjava.lang.NullPointerException: Cannot get property 'profileId' on null object on line 79 (method parse)
When it becomes unresponsive, can you connect to port 8081? What color is the light when it becomes unresponsive? What version of hub firmware? What is app 41? What is device 164 and device 165?
It sounds like you may be running with a corrupted database, have you tried to run a Soft Reset to see if that resolves the problem?
I will try a soft reset to see if it makes a difference.
  1. Next time it locks up, I will try to access port 8081. I have not tried that.
  2. I will note the Hub light status too on the next lock-up.
  3. I am running 2.3.5.125 and just updated to 2.3.5.131.
  4. App 41 is Life 360. I don't use that, so I removed it.
  5. Devices 164 and 165 and 165 are Quirky Moisture Sensors.
