C7 Elevation, No Devices showing up in Z-Wave Inclusion
Seems like maybe your zwave radio is offline or something.
Try these ones:
/hub/zwave/healthStatus
/hub/zwaveDetails/json
Might give a better idea.
Also FULL results of http://YOUR.HUB.IP/hub/zwaveVersion I think if the radio is down it will either not work or not look correct. Should be a JSON string.
The results in order were:
/hub/zwave/healthStatus = true
/hub/zwaveDetails/json = {"showSecureJoin":false,"showRegion":true,"secureJoin":0,"zwaveIP":true,"zwaveJSAvailable":true,"zwaveJS":false,"enabled":true,"zwDevices":{},"isRadioUpdateNeeded":true,"region":"US","nodes":}
http://YOUR.HUB.IP/hub/zwaveVersion = not found
Im going to do a full reset.
That's the one I said to check 3 times prior and you stated it was showing 7.15, I am guessing that was the SDK version endpoint from the other instructions.
The zwaveVersion output is like this:
VersionReport(zWaveLibraryType:7, zWaveProtocolVersion:7, zWaveProtocolSubVersion:18, firmware0Version:7, firmware0SubVersion:18, hardwareVersion:1, firmwareTargets:1, targetVersions:[[target:1, version:7, subVersion:18]])
When that endpoint says it is not found, it is a telltale sign of a dead z-wave radio.
Okay, thank you for your help!
