C7 Blu light new thread as requested
For reference for others: Blue light special...c7
@rdvancleave, you have the hub connected directly to the router via ethernet?
You should have some lights on the ports for your switch/router, is it showing the link light for that port?
What The Ethernet Port LEDs Mean On A Room Alert Monitor - AVTECH
Can you check your router interface to see if the hub has established an unexpected IP? You may need to make note of the MAC on the bottom of the hub and then look for that, the name shown may not indicate it is the HE hub.
You can also run arp -a from a command line on a PC and then look through the results of that for the MAC
