C5 Not booting stuck at 30%
C5 running 2.2.7.126 Will not boot gets stuck at 30%. I tried unplugging for a minute and plugging back in and still stuck at 30%. Then went in and enabled safe mode now stuck at 80%.
Try performing a Soft Reset with restore, if you didn't already.
https://docs.hubitat.com/index.php?title=Soft_Reset
Were you trying to update when this happened?
@bobbyD Thanks was working on that hope the restore goes well.
@bobbyD That did it, Thanks.
Glad to hear. Screen your logs to make sure that something is not going crazy. Soft Reset is good to get your hub back online, but problems may persist, and you'd be right back where you were if not addressed. If you see no errors, then you're good.
