The logs just stopped at 10PM.
Some of the z wave devices don’t seem to be reporting accurate state. I was unable to turn off a couple of them last night using the web api.
I am seeing this:
dev:3602023-10-08 07:38:28.147 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:28.045 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:28.042 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:27.433 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:27.430 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:27.429 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:27.427 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:27.099 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:27.097 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:23.025 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:23.024 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:23.022 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:23.020 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:22.582 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:22.580 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:22.459 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:22.456 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:22.371 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:22.369 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:21.999 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:21.997 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:21.954 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:21.951 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:21.878 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:21.875 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:21.005 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:21.002 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:38:09.374 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:09.371 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:08.099 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:08.097 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:08.089 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:08.086 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:07.648 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:07.645 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:07.458 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:07.456 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:07.330 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:07.328 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:07.321 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:07.319 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:07.314 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:07.311 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:07.181 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:07.178 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:05.775 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:05.774 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:05.773 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:05.772 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:04.733 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:04.730 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:04.317 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:04.315 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:03.883 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:38:03.880 PMdebugparse:zw device: 31, command: 2503, payload: 00 00 00 , isMulticast: false
dev:3602023-10-08 07:38:03.874 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:03.872 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:03.739 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:03.737 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:03.731 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:03.728 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:03.612 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:03.610 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:03.434 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:03.431 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:03.002 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:02.999 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:02.499 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:02.497 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:02.114 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:02.111 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:01.709 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:01.707 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:00.823 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:00.821 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:00.399 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:00.396 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:38:00.354 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:38:00.351 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:37:59.427 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:37:59.425 PMdebugparse:zw device: 31, command: 2503, payload: FF FF 00 , isMulticast: false
dev:3602023-10-08 07:37:59.072 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:37:59.069 PMdebugparse:zw device: 31, command: 2503, payload: FF FF 00 , isMulticast: false
dev:3602023-10-08 07:37:58.989 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:37:58.987 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:37:58.623 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:37:58.620 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:37:58.536 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:37:58.534 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:3602023-10-08 07:37:58.478 PMinfoBedroom Switch was turned on
dev:3602023-10-08 07:37:58.475 PMdebugparse:zw device: 31, command: 2503, payload: FF , isMulticast: false
dev:4902023-10-08 07:37:41.653 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:37:41.650 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:37:41.297 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:37:41.295 PMinfoBedroom Fan button 1 was pushed
dev:4892023-10-08 07:35:58.652 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:35:58.181 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:35:58.157 PMinfoKitchen Sink Light is off [digital]
dev:102023-10-08 07:34:34.640 PMinfoBack Office Multisensor: illuminance is 21lux
dev:102023-10-08 07:34:34.622 PMinfoBack Office Multisensor: temperature is 80.60°F
dev:102023-10-08 07:34:34.621 PMinfoBack Office Multisensor: humidity is 31%
dev:4232023-10-08 07:34:22.416 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:34:22.413 PMinfoOffice Fan button 2 was pushed
dev:4892023-10-08 07:33:38.311 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:33:38.243 PMinfoKitchen Sink Light was turned off [digital]
dev:4232023-10-08 07:30:25.904 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:30:25.890 PMinfoOffice Fan button 2 was pushed
dev:4892023-10-08 07:30:25.678 PMinfoKitchen Sink Light was turned on [physical]
dev:4902023-10-08 07:25:49.423 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:25:49.421 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:25:24.802 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:25:24.800 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:25:24.797 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:25:24.776 PMinfoBedroom Fan button 1 was pushed
dev:4892023-10-08 07:24:43.501 PMinfoKitchen Sink Light is off [physical]
dev:342023-10-08 07:24:41.798 PMinfoCabinets Switch is off [physical]
dev:4902023-10-08 07:24:41.023 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:24:41.020 PMinfoBedroom Fan button 1 was pushed
dev:4232023-10-08 07:24:40.687 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:24:40.685 PMinfoOffice Fan button 2 was pushed
dev:4902023-10-08 07:24:38.244 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:24:38.242 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:24:38.197 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:24:38.195 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:24:38.125 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:24:38.122 PMinfoBedroom Fan button 1 was pushed
dev:102023-10-08 07:23:23.136 PMinfoBack Office Multisensor: illuminance is 1lux
dev:102023-10-08 07:23:23.097 PMinfoBack Office Multisensor: humidity is 31%
dev:102023-10-08 07:23:22.953 PMinfoBack Office Multisensor: temperature is 80.75°F
dev:4902023-10-08 07:23:02.842 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:23:02.840 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:23:02.779 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:23:02.777 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:23:02.728 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:23:02.726 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:23:02.473 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:23:02.471 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:23:02.397 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:23:02.395 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:23:02.330 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:23:02.328 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:39.156 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:39.154 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:39.016 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:39.013 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.832 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.830 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.788 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.786 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.763 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.761 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.719 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.717 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.654 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.651 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.589 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.587 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.402 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.400 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:38.345 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:38.343 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:36.346 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:36.344 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:36.079 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:36.077 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:28.639 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:28.637 PMinfoBedroom Fan button 1 was pushed
dev:4232023-10-08 07:22:26.295 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:22:26.281 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:22:26.203 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:22:26.201 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:22:26.022 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:22:26.020 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:22:18.795 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:22:18.793 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:22:18.637 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:22:18.635 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:22:18.613 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:22:18.610 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:22:18.553 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:22:18.550 PMinfoOffice Fan button 2 was pushed
dev:3602023-10-08 07:22:17.542 PMinfoBedroom Switch button 2 pushed
dev:3602023-10-08 07:22:17.477 PMdebugparse:zw device: 31, command: 5B03, payload: 60 80 02 , isMulticast: false
dev:3602023-10-08 07:22:17.191 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:22:17.189 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:22:15.878 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:22:15.875 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:22:15.753 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:22:15.751 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:3602023-10-08 07:22:15.661 PMinfoBedroom Switch was turned off
dev:3602023-10-08 07:22:15.658 PMdebugparse:zw device: 31, command: 2503, payload: 00 , isMulticast: false
dev:342023-10-08 07:22:15.273 PMinfoCabinets Switch is off [physical]
dev:342023-10-08 07:22:14.996 PMinfoCabinets Switch is off [physical]
dev:342023-10-08 07:22:14.901 PMinfoCabinets Switch is off [physical]
dev:342023-10-08 07:22:14.839 PMinfoCabinets Switch is off [physical]
dev:342023-10-08 07:22:13.101 PMinfoCabinets Switch is off [physical]
dev:342023-10-08 07:22:11.244 PMinfoCabinets Switch is off [physical]
dev:4892023-10-08 07:22:10.895 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:10.444 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:10.374 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:10.060 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:10.022 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:09.958 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:09.863 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:09.744 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:22:09.677 PMinfoKitchen Sink Light is off [physical]
dev:4902023-10-08 07:22:07.901 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:07.899 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:06.746 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:06.744 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:22:06.714 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:22:06.711 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:57.946 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:57.943 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:57.644 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:57.642 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:57.598 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:57.595 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:57.319 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:57.317 PMinfoBedroom Fan button 1 was pushed
dev:4232023-10-08 07:21:48.357 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:21:48.354 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:21:48.233 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:21:48.231 PMinfoOffice Fan button 2 was pushed
dev:4902023-10-08 07:21:44.555 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:44.553 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:44.246 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:44.244 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:44.148 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:44.146 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:43.747 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:43.745 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:43.695 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:43.693 PMinfoBedroom Fan button 1 was pushed
dev:4232023-10-08 07:21:28.153 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:21:28.151 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:21:28.118 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:21:28.115 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:21:28.100 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:21:28.098 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:21:27.733 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:21:27.730 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:21:27.592 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:21:27.589 PMinfoOffice Fan button 2 was pushed
dev:4892023-10-08 07:21:14.368 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:14.035 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:13.940 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:13.692 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:13.550 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:13.459 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:13.393 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:13.313 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:12.897 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:12.812 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:12.690 PMinfoKitchen Sink Light is off [physical]
dev:4892023-10-08 07:21:12.198 PMinfoKitchen Sink Light is off [physical]
dev:342023-10-08 07:21:11.576 PMinfoCabinets Switch is off [physical]
dev:4902023-10-08 07:21:10.267 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:10.265 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:09.779 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:09.777 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:09.723 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:09.721 PMinfoBedroom Fan button 1 was pushed
dev:4902023-10-08 07:21:09.514 PMinfoBedroom Fan is high [physical]
dev:4902023-10-08 07:21:09.511 PMinfoBedroom Fan button 1 was pushed
dev:4232023-10-08 07:19:31.360 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:31.358 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:29.697 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:29.695 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:29.137 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:29.136 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:29.135 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:29.133 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:26.912 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:26.910 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:26.242 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:26.240 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:25.877 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:25.875 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:25.830 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:25.828 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:25.803 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:25.801 PMinfoOffice Fan button 2 was pushed
dev:4232023-10-08 07:19:25.633 PMinfoOffice Fan is off [physical]
dev:4232023-10-08 07:19:25.631 PMinfoOffice Fan button 2 was
