Yes on the old C4 and the new C7
I would start by reboot the hub gracefully (settings -> reboot)
- see if it works
I would then either HPM repair, or manually update (cut/paste) in the webcore code into the hub.
- the piston file and the webcore.groovy file
I would reboot the hub gracefully after that.
Can have logs open in HE console to see if something shows up as an issue.
I assume the HE hub is not blocked from internet access (webcore talks to webcore servers) ?
Eventually finished the transfer, everything done manually and cross fingers working fine
