I've had my Hubitat C4 for ages, but last night it seems to have died. I was able to interact with it yesterday evening (Alexa request to turn on the lights) but sometime between 8:33PM and 8:37PM it disappeared from the network according to homebridge. I attempted to ping it and connect to the diagnostic UI without success, so then I unplugged it completely and left it for 5 min, the powered up again. No luck.
I moved the hub to another location (new power bar source, new cable, new switch) that my home computer shares and tried again, but still get the same result - blue light, no network connectivity.
I didn't interact with it at all in the time between 8:33PM and 8:37PM (no reboots, firmware updates etc) so I'm not sure what could have happened.
I can use the hubitat "find" tool with the mac address, and it shows me the IP address I expect to get, but still no dice. Any ideas on what to try?
Have you tried accessing port 8081 of that IP address? It is possible that the platform isn't running (port 80), but the Diagnostic Tool (port 8081) is.
That's my expected diagnosis. I was hoping there might be some way to see the boot logs to find out why it was busted. I tried plugging in HDMI to see if it output some kind of diagnostics but nada.
Is there a way to migrate the network from the USB-attached radio on the C4 to a new C7, or do I need to manually reset every device and start from scratch?
Unfortunately, no. You will need to exclude/reinclude/reset/repair all your devices. Even if you have Hub Protect, the hardware in the C4 doesn't allow Z-Wave restoration. However, I strongly recommend enrolling your new hub in the Hub Protect service, so you can restore the radios and have a cloud backup readily available to minimize downtime, the next time an unfortunate event happens.
Mine is still going, but in a development capacity... C-7's all the way in a Production capacity.... Run cool and quick, with the occasional restart. If I spent the time to optimise my choice of apps and setup, can't see any reason I couldn't run off a C-4, just needs a little more love than a C-7.
what actually dies in them? it seems to be all solid state and passive cooled (I popped it open to check it out). Is it too much wear on the NAND or something?
