Our C4 hub worked for over a year, and had a couple intermittent issues that were resolved by a soft reset and a hard power reset a few weeks later after it went unresponsive again. After some storms caused some power outages the hub stopped working in September.
I am not able to access it by the IP address or by the MAC address. I have tried plugging in different Ethernet cables, plugging it in directly to do the router, and confirming the power source is working. The external USB hard drive is showing a blue light.
Can you please give me some next steps on what else to try to get my device working again?
Yeah I experienced similar some years ago.. I had 2 C4 hubs at the time. When the one died ended up replacing both just in case. Very similar symptoms.
I hope yours comes back but you might consider upgrading and taking advantage of the backup/transfer service (clarification: for future upgrades/transfers etc) as well. Not available for the C4 unfortunately.
I can check to see if the hub is connecting to the cloud, but based on the details that @user3556 provided, it sounds like the hub dropped off the network, so chances are that engineering logs cannot be retrieved. @user3556 if you'd like me to check, please send me your hub's MAC address via private message.
