I know there have been a number of users who are (or were) having issues with their Hubitat C-8 becoming unresponsive (can't be accessed by app) unless the unit is power cycled. Once power cycled everything works great, and I'm just curious if the issue has gone away and if so what has worked for them. I hope this doesn't offend anyone just seeing how it's playing out.
@user5896 - Have you found a solution or did a replacement hub work for you? @Bachinat0r - Has your replacement hub fixed your issue? @lovejackie6 - Did you get a solution, if so what was it? @KJL - Did the ethernet switch work for you? @street9009 - Have you been able to find a solution? @bwilfong15 - It looks like your issues is a bit different but I was just curious how things are going since you've taken the remedial steps?
Had to create another copy because I mentioned to many users with the total message. Again just curious on the resolutions people are finding.
@RSLaufer - Curious on how your system is humming along, if it's working could you provide a bit of summary what worked for you? @mccoart - Are you still having issues? @Salieri - Are you still having issues? @JoeP - How long have you been in the clear since you've gone wired? I've gone wired and wireless and it's dropping less frequently on wireless but still having issues. @user5027 -How is your system running, still having issues? @DeltaV - Are you still having issues? @DrRomca - How's it looking for your hub, have you found a resolution? @lagpro - Are you still having issues? @itzMalice - Since getting it replaced have you had any issues or is it all good? @user6904 - Have you found a resolution?
It is difficult to pin down the actual cause. I think it might be related to the fact that I initially set up the C8 as wireless, but switched to a wired connection when I discovered that the wireless connection could not ve set up with a static IP.
I did also move the hub around a little, so maybe some RF hub was producing some interference?
I did finish up setting up IoT devices and removed those that were polling excessively.
So far, so good.
I hope it stays this way as I add additional devices and rules to my C8.
Mine had to do with the hub running at a high temperature. A low power setting was set on the backend by Hubitat support and that appears to have resolved the issue. Additionally, if that wasn't going to work, they were prepared to send me a replacement hub and opened a case for me. Kudos to bobbyd and gopher.ny for their help.
No issues seen thus far since the hub locked up and was rebooted on 2023-09-26 while running 2.3.6.134. Successfully upgraded to 2.3.6.140 on 2023-10-02, and zero lockups or restarts afterwards. Performing an upgrade to 2.3.6.144 right now.
@King - With many posts to the community with my issue and also direct messaging through X (Twitter); it was determined by support that the Zigbee radio in my C-8 was causing the issue. I had some options and ultimately chose the replacement. Since the replacement I have NOT had the issue; except for 1 time but I had also updated both of my Apple TV's and the backup took over as the primary apple home controller. Also I was able to access the diagnostic page of the C-8 so I just restarted it (important to check that also, since it turns out that simply removing power from the device can cause a database corruption, which support also said I had before the replacement).
Also note I have not switched back to wireless connectivity. I switched to wired during troubleshooting before my replacement and simply haven't switch back.
@King - I've not had the issue as of late. One of the things I was waiting to do was try the diagnostic tool the next time I saw the issue. I have not opened a ticket but perhaps I should.
@bobbyD was saying that Hubitat doesn't work with Asus very well. Bobby is this in any documentation? I bought new routers prior to going with the Hubitat since I was moving away from my SmartThings platform.
Would be good to know, do you have a single ASUS router or a mesh system?
I have a single AX68U which would sometimes disconnect all my 5ghz clients at random for only a second. Its somewhat of a known issue with the chipset that router uses. All the clients usually recover except my smart TV sometimes does not reconnect and has to be rebooted. I turned off ALL the TrendMicro stuff by revoking the privacy agreement almost a month ago and it has been much better ever since then. I could possibly test my C8 on it within the next few weeks.
No, we are not tracking network isssues and incompatibilities because networking is such a wide field and greatly depends on individual abilities to manage their own equipment.
But this is a known flaw that you (support) recognizes and the community knows about it. It should be listed otherwise you're just building towards disappointment with your consumer base right? Why shouldn't you have it documented somewhere?
That's what I've been told by support or other community members. Are they running the unit Wi-Fi or jacked in? @JoeP has ASUS and it's only working on ethernet.
I have a mesh system, essentially two ASUS ZenWiFi AX6600 Tri-Band Mesh WiFi 6 units, one in the basement and one on the first level. I had one closer to the Hubitat but when it was running WiFi it dropped out more and I figured network interference might be at play. When I moved the AX6600 into another room the drops happen less frequently.
I'd love to hear back from your testing with the ASUS router.
During the C-8 beta test period, I had a C-8 connected to an ASUS router both hardwired and wirelessly. I gave that router to goodwill during a recent move, and Iβm blanking on the model.
There were some issues during the beta with getting an IP address during wireless connection, but they were resolved very early on.
I worked for one of the largest consumer electronics companies and we had very similar issues - known networking equipment that could cause serious problems w/our equipment in some instances, but in other (often most) cases worked quite well.
Very hard to predict, and impossible to reliably replicate in our internal labs (and we had way more resources than HE). Completely frustrating for both customers and support alike.
