I had a C-8 Hub that recently died. I opted to upgrade to the C-8 Pro. I had a migration cloud backup ready, so not worries.
I have followed the instrutions to migrate to the new C-8 Pro and everything went great, except everything seems to be in "Read Only" mode. I have an array of Z-Wave, Zigbee and Virtual devices, including switches, open/close sensors, water sensors, plus connetions to Hue, Netatmo, Ring, etc. The state of all of these devices shows exactly as they did at the backup but none of them will change.
For example, I have a virtual switch. The switch shows as "On". From the Devices screen, I switch it to "Off"... but nothing happens. It remains on. If I turn on logging, I see the log entry of the switch being turned off, soon followed by a message that tells me the switch is "on". This is true of every device - Z-Wave, Zigbee, Virtual, etc.
I have Maker API installed and it feeds the status out to the world, but again, no changes to any device state is registered.
In addition, I am using Webcore, currently installed as an app. (I haven't migrated to native, yet). Trying to start webcore just hangs the app.
I have tried a few tricks, including reboots, power cycles, etc.
I tried doing a restore from the cloud backup, then creating a local backup and doing a soft reset from the local backup, with power cycles after restore.
Nothing changes.
Platform Version: 2.3.9.160
Hardware Version: C-8 Pro
Nothing fancy in the network setup... certainly nothing that has changed since the C-8 was working and decided to bite the dust.
Any ideas of things I should be trying? It is incredibly frustrating.
