C-8 Pro z-wave is unresponsive (after upgrading from C-5 and also setting up as new hub) v2.3.8.139
Hi, I've tried multiple scenarios and multiple times to migrate from a C5 to a C-8 Pro. I am able to get all zigbee devices working, but I cannot get any z-wave devices to respond and always get z-wave is unresponsive. I've tried removing all z-wave devices from the C-8 pro as well as just tried to set up the new c-8 Pro from scratch (without and restore) and even with nothing configured on the new c-8 Pro, it comes up with "z-wave is unresponsive". I'm not seeing anything in the logs and attempting any type of repair never completes. At one point, I have had all z-wave devices powered off - along with them being removed from the c-8 Pro and still get "z-wave is unresponsive"
Also, all devices work on the C-5 and I have no ghost devices on the C-5 (from what I can see). And I have reviewed and tried most scenarios that have been posted in the community
Help please!
I would at this point go to support.hubitat.com and click warranty at the bottom.
While you're waiting, is there anything in your logs?
I assume you did the cloud migration and not just restore a local backup to the new hub.
Reset the z-wave radio, factory reset a device then see if you can pair that device. Open a live log on your pc while doing so.
Check this post, might be same issue with your C8
Just need to go to the endpoint in your browser and wait for it to think for a while.
http://HUB.IP/hub/advanced/installZipgateway718
