Hi everyone,
I'm hoping someone can point me in the right direction. I've spent quite a bit of time troubleshooting this and have reached the point where I'm not sure whether I'm looking at a software issue, a hardware issue, or something I've overlooked.
Hub Information
Hub: Hubitat C-8 Pro
Platform Version: 2.5.0.159
Z-Wave Radio Firmware: 7.18.1
Region: US-LR (908.4 / 916 MHz)
LR Channel: B
Device
Zooz ZSE41 800LR
Firmware 2.30
US version
Symptoms
I've never successfully included a Z-Wave Long Range device on this hub.
My conventional Z-Wave mesh is healthy and functioning normally, but every attempt at LR inclusion fails.
The controller log consistently follows this sequence:
SmartStart request received > DSK recognized > "Including SmartStart node using Z-Wave Long Range" > NodeFound > Adding the node failed
The hub clearly sees the device and begins LR inclusion, but the inclusion never completes and no device is created.
What I've Tried:
- Shut the hub down properly and removed power for 30+ seconds before retrying.
- Verified the hub and sensor are both running current firmware.
- Verified the hub is configured for the US LR region.
- Antenna Test passes with no reported issues.
- Reviewed my Z-Wave Details page for ghost or incomplete LR nodes and don't see anything that appears related to the failed inclusion.
My Z-Wave network appears to be working normally.
The sensor is located only a few feet from the hub during inclusion, so I don't believe this is an RF range issue.
From the logs, it appears the hub successfully discovers the device but aborts during the LR inclusion process before creating a node.
Has anyone seen this specific "NodeFound" > "Adding the node failed" sequence with LR devices? Are there any known issues with Hubitat 2.5.0.159 or Z-Wave firmware 7.18.1 affecting LR inclusion? Is there anything else worth checking before I open a support ticket?
Any ideas would be greatly appreciated.
