C-8 Pro Bluetooth Integration (Beta) — Speaker discovery stops after Echo pairing attempt
Hardware: Hubitat C-8 Pro
Platform: 2.5.2.129 initially, subsequently updated to 2.5.2.139
Initially, Bluetooth Integration successfully discovered four devices, including an Echo Dot, two Bluetooth audio devices, and a Samsung TV.
I attempted to pair the Echo using the Pair w/Alexa option. The pairing did not complete, and the logs subsequently showed:
method appButtonHandler of app Bluetooth Integration (beta) ran for 166,992ms
Since then, Bluetooth speaker discovery consistently returns No Bluetooth speakers found.
Troubleshooting completed:
  • Restarted the Bluetooth integration.
  • Removed and reinstalled the integration.
  • Updated the Hubitat platform.
  • Removed the integration, rebooted the C-8 Pro, and reinstalled it.
  • Tested with a Bose SoundLink Color confirmed to be in Bluetooth pairing mode.
Discovery still returns no devices.
Is there a known issue with the Bluetooth service following an unsuccessful Alexa pairing attempt? Is there a way to reset the Bluetooth subsystem independently of the integration?
Please reboot the hub for now. Something is stuck and is not going to recover, and we (as in Hubitat engineers) need to investigate. Also, please PM me the hub id, hopefully there are some useful details in the engineering log.
Thank you. Not finding a way to PM you. Perhaps send me a PM and I will reply.
Click on @gopher.ny avatar and then click on the green message button.
Tried that but no message button appears. Not sure what I’m missing here. I am logged in.
Try it again. I just raised your forum account privileges from “new user” to “member” so you can send PMs and also add images to your posts.
There it is, thank you
