Is there a particular place we should submit bluetooth device support requests to?
I'd like to see the Tru-Scapes Color Changing Hardscape Light (TS-A6000C) supported.
I would be happy to send one of these fixtures to the developers if it would help.
Thanks!
As I understand it, the pathway to Bluetooth integration is via an open standard called BTHome:
Perhaps it will be possible for the hub to work with other kinds of Bluetooth devices in the future that adopt a more closed off approach.
aaiyar
4
If you have Home Assistant, you can integrate them into Hubitat using a Tuya Bluetooth gateway. And HADB.
