C-8 lutron picos stopped working after migration
I have a C-8, running 2.3.7.144
Reserved IP, DHCP, connected to a 100MB hub
Yesterday, I migrated from my C-7 to my C-8
My timezone is set correctly and shows accurate time
I can see and trigger most or all of my devices
I don't have any zwave ghosts, I have done a zwave repair.
I'm not getting any excessive load errors
In my logs, in the past few hours, the only error/warn events were for a Ring device I wasn't using, so I removed that
PROBLEM: my lutron picos are not triggering
I can see immediate actions in my logs.
dev:967 2023-12-31 06:13:10.863 AM info rcvd: DEVICE,2,2,4
dev:967 2023-12-31 06:13:10.643 AM info rcvd: DEVICE,2,2,3
I am able to control my lutron dimmers, but my picos are not responding. If I change my picos from a "p," to a "q,", I can create a rule button rule that works with the Q devices and pressing buttons works, but I lose the extended button actions and I only get a press/hold action. So I've switched my lutron configs back to "p," devices.
I did try a soft reset, but on a migration .. this probably shouldn't be necessary.
I've shutdown and powered off a few times to restart the hub.
An unmatched device id was linked to broken scheduler entries.
After the device jobs were deleted, and I rebooted .. all my services came back online
All my picos are working now. I did have to relink my button controllers and I had to switch the 2 button picos to set as 2 button picos, but I'm now able to use my buttons.
I ended up sending a backup file to one if the support members and they were able to identify the broken process.
