C-8 Elevation Pro + Zooz Titan + Homekit + Newbie
Here is what musing out loud gets you. A cousin-in-law and certified tech god gifted me a Zooz Titan valve he was unable to use. After much hemming and hawing I decided the Hubitat was my best bet for z-wave, zigbee, matter, and whatever else I might need after I get done with Lutron, My-Q, Schlage and Flume. The Hubitat hubbed up, updated and the Titan connected mostly on the first try.
However, my attempts to have the valve be a valve in Homekit are a bust. Don’t want an automation, just want an easy button to turn the water off when the water heater fails. The Titan valve shows up as a valve + temperature sensor in Hubitat, then sheds the valve title while going to the Apple Homekit cosmos, which I am literally wedded to along with kids and grandkids.
Any thoughts or advice?
Easy way - Create a virtual switch in Hubitat which you share to HomeKit. Then in Hubitat create a rule or rules using the virtual switch as the trigger - virtual switch turns on - valve opens, virtual switch turns off - valve closes.
Thanks! That sounds like the very easy fix.
This is actually very easy to resolve, without any additional automations (although you could certainly go that route).
In Hubitat terms, your Titan valve has two capabilities:
  1. Valve
  2. Temperature sensor
You only want one of those capabilities to be exposed to Apple Home via the built-in HomeKit integration (i.e. only the valve capability). Here's how you do it:
  1. When you open the Homekit integration app, and select the valve, you will see the valve presented as (see the screenshot below):
    Export as: Temperature Sensor, Valve, Water Sensor
    Extras: Temperature Sensor (-)
  1. Click on the minus sign next to Temperature Sensor. You'll be presented with the following dialog box.
  1. If you click on Yes, then the Valve now presents itself as just Valve and Water Sensor (see below - Temperature Sensor is an extra that can be added).
Screenshot 2026-02-18 at 10.13.17
Finally click on Done. Now, within Apple Home, the valve will only present itself as a Valve (and Water Sensor), but not as a Temperature Sensor.
Thanks! That worked just as you showed it would.
