C-7 Zooz Multirelay issues with 2.2.3
I'm showing "ignore SupervisionGet" in the log when child devices are operated. This is with a Zooz ZEN16 using the builtin Zooz MultiRelay driver on 2.2.3.118.
Also, child devices are not receiving events such as switch on/off when operated. The events are showing as being for the parent device.
Can you post a screen shot of these logs with debug logging enabled when you command it?, thanks.
Hey Mike, I will as soon as I can. Right now I'm kind of dead in the water with Busy messages.
That's more than likely not helping the lock situation.
We are working on the busy message issue, so we probably want to get that hot fix in place then see if that resolves your lock issue.
Mike, Do screenshots these help?
Screen Shot 2020-08-15 at 3.54.54 PM Screen Shot 2020-08-15 at 3.54.23 PM
...sorry. Here's the log with debug logging on: (relay works and shuts off, but dash-tile gets stuck on "sending"
dev:362020-08-15 04:11:18.426 pm debugignore: SupervisionGet(statusUpdates:false, reserved:0, sessionID:46, commandLength:3, commandClassIdentifier:32, commandIdentifier:3, commandByte:[0]) (Endpoint 1)
dev:362020-08-15 04:11:17.907 pm info28897 Relay: switch is off
dev:362020-08-15 04:11:17.903 pm debugBasicReport(value:0)
dev:362020-08-15 04:11:16.117 pm debugignore: SupervisionGet(statusUpdates:false, reserved:0, sessionID:44, commandLength:3, commandClassIdentifier:37, commandIdentifier:3, commandByte:[255]) (Endpoint 1)
dev:362020-08-15 04:11:15.680 pm info28897 Relay: switch is on
dev:362020-08-15 04:11:15.673 pm debugSwitchBinaryReport(value:255)
dev:362020-08-15 04:11:15.467 pm debugcomponentOn(28897 Relay-Relay 1)...
--- Live Log Started, waiting for events ---
In case anyone comes across this later, this was addressed in 2.2.3.135.
