A couple of weeks ago my C-7 started freezing every now and then.
Before that it would typically run for at least a month or two without hanging.
This time I tried accessing the Diagnostic Tool at xxx.xxx.xxx.xxx:8081. No dice. Completely unresponsive. The firmware version is 2.3.7.146.
Besides the log portion below, is there anything else I could upload here that might help troubleshoot? As far as devices, I have about 10 Centralite smart outlets (all using the Iris Smart Plug driver), three Environment Sensor EX, and a Sinope Load Controller RM3250ZB with energy meter (all of these items are on Zigbee), and a Lutron hub with three Pico button units. A few simple Rule Machine automations to turn things on and off. That's it. My system was originally running on a C-5 [edit: C-4], and it would occasionally hang as well, but pretty rarely; maybe once every 3 months. I'm wondering if I should put in a rule that reboots the unit every night around midnight??
Here is the latest portion of the log (apparently hung right after 8:07 AM; I rebooted it at 5:09 PM):
dev:592024-02-10 17:09:13.558infoTelnet connection to Lutron interface established
dev:202024-02-10 17:09:13.199warnDID NOT PARSE MESSAGE for description : catchall: 0000 8032 00 00 0040 00 4B3E 00 00 0000 00 00 00000A0109744A01744ADE6C01EBFF00000300000000030000EF5000F91E8C2C00F91EAD9300F91E00000300000000030000
dev:22024-02-10 17:09:12.995warnDID NOT PARSE MESSAGE for description : catchall: 0000 8032 00 00 0040 00 6CDE 00 00 0000 00 00 00000A01094F18004F18CFDF00CFDF744A010000000003000000000300000000030000000003000000000300000000030000
dev:12024-02-10 17:09:12.980warnDID NOT PARSE MESSAGE for description : catchall: 0000 8032 00 00 0040 00 CF0E 00 00 0000 00 00 00000A0109C4F800DE6CCFDF00CFDF4F1800CFDF744A01870C42FC0042FC0000030000000003000000000300000000030000
dev:162024-02-10 17:09:13.187warnDID NOT PARSE MESSAGE for description : catchall: 0000 8032 00 00 0040 00 44B3 00 00 0000 00 00 00000A0109C4F8004F18744A013E4B4F18004F18CFDF00CFDF42FC0042FC0000030000000003000000000300000000030000
dev:32024-02-10 17:09:12.977warnDID NOT PARSE MESSAGE for description : catchall: 0000 8032 00 00 0040 00 4A74 00 00 0000 00 00 00000A01094F1800CFDFCFDF00CFDF0000030000000003000000000300000000030000000003000000000300000000030000
dev:42024-02-10 17:09:12.985warnDID NOT PARSE MESSAGE for description : catchall: 0000 8032 00 00 0040 00 34B4 00 00 0000 00 00 00000A0109D4F6003E4B4F18004F18CFDF00CFDF42FC0042FC744A010000DE6C01EBFF000003000000000300000000030000
dev:182024-02-10 17:09:12.981warnDID NOT PARSE MESSAGE for description : catchall: 0000 8032 00 00 0040 00 FFEB 00 00 0000 00 00 00000A0109744A00744AEF5000F91E8C2C00F91EC0F300F91EAD9300F91ECFDF00CFDF000003000000000300000000030000
dev:592024-02-10 17:09:12.728infoLutron Telnet is still online
dev:572024-02-10 08:07:36.783infoGuestBathHWR button 3 was pushed
dev:592024-02-10 08:07:36.775inforcvd: DEVICE,3,3,3
dev:572024-02-10 08:07:34.671infoGuestBathHWR button 5 was released
dev:592024-02-10 08:07:34.662inforcvd: DEVICE,3,4,4
dev:572024-02-10 08:07:34.369infoGuestBathHWR button 5 was pushed
dev:592024-02-10 08:07:34.360inforcvd: DEVICE,3,4,3
dev:572024-02-10 08:07:33.669infoGuestBathHWR button 1 was released
dev:592024-02-10 08:07:33.611inforcvd: DEVICE,3,2,4
dev:572024-02-10 08:07:33.168infoGuestBathHWR button 1 was pushed
dev:592024-02-10 08:07:33.159inforcvd: DEVICE,3,2,3
dev:572024-02-10 08:07:33.018infoGuestBathHWR button 3 was released
dev:592024-02-10 08:07:33.010inforcvd: DEVICE,3,3,4
dev:572024-02-10 08:07:32.198infoGuestBathHWR button 3 was pushed
dev:592024-02-10 08:07:32.189inforcvd: DEVICE,3,3,3
dev:572024-02-10 08:07:30.273infoGuestBathHWR button 3 was released
dev:592024-02-10 08:07:30.265inforcvd: DEVICE,3,3,4
dev:572024-02-10 08:07:29.301infoGuestBathHWR button 3 was pushed
dev:592024-02-10 08:07:29.292inforcvd: DEVICE,3,3,3
dev:572024-02-10 08:07:27.629infoGuestBathHWR button 3 was released
dev:592024-02-10 08:07:27.620inforcvd: DEVICE,3,3,4
dev:572024-02-10 08:07:26.594infoGuestBathHWR button 3 was pushed
dev:592024-02-10 08:07:26.568inforcvd: DEVICE,3,3,3
dev:572024-02-10 02:05:18.861infoGuestBathHWR button 3 was pushed
dev:592024-02-10 02:05:18.830inforcvd: DEVICE,3,3,3
