@mike.maxwell I am tagging you since you are the driver guru..
I have a Zooz ZEN20 power strip installed on my C-4 HE hub. It is using the built-in Zooz Power Strip driver. It has all of the Preference options as shown here:
I have a buddy I have been helping with his new C-7 hub. We installed his Zooz ZEN20 power strip on his and it is working correctly and created the 5 component child devices. However, he has none of the Preference options available to him. Here is a screenshot of his options:
We have installed it non-securely, securely, it makes no difference. Here are the data details should you need them from the C-7:
I've got a similar issue. I had a couple of C5s and upgraded to C7s. I've got 8 of these Zooz Power Strips and 2 of the 8 don't have all the preferences options that the other 6 do.
Just thought I would share since the last update on this topic was 8/20.
Did they by chance pick up the wrong driver when paired? Also have you tried hitting configure? I am guessing there is a State Variable or Device Details data point that did not load correctly and it is causing the preferences to not show. Only a dev who can see the driver code would know for sure.
