Family members keep tripping the alarm to let dogs in/out.
I am wondering if there is a way to have a physical button (or a combo sensor with button) at my front and back doors that family members can use to temporarily bypass the alarm without disarming the whole alarm system. I was impressed by the Nest Secure sensor and Quiet Open, but not enough to actually use Nest Secure.
It depends a lot on what device you use for your contact sensors.
If it uses an inbuilt driver then it more difficult than using a custom driver.
If it’s a custom driver then a ‘switch’ capability could be added that disables the action of the sensor.. you could then use button controller to ‘toggle’ the enable/disable ‘switch’
If it is an inbuilt driver then I would personally use a virtual contact sensor and write a little app (or possibly use a rule in RM) to control it with a button and put it inbetween your door sensor and HSM
@Cobra
Always with the obvious simple solution, Mr. Parker. I was hoping for something extremely difficult and painful with plenty of cranial explosions. Sigh.
I forgot to ask the obvious. Do you have a recommendation for a wireless button I can stick up by the doors? I am all Zigbee for the moment, but would consider well behaved Z-wave device.
