I'm not even sure it's supposed to work.
I put a button on the dashboard to control a virtual switch. The button is from a @JasonJoel driven GE switch. The actual physical button works fine. The log is below. Any thoughts?
Depending on which specific driver of mine you're using, it might not work. On most of the drivers I didn't actually put any code behind the push event from The hub side, as I didn't think anyone would ever use it for that. That said on at least one of the drivers I did go back and add that code, so could probably add it on whatever driver you're using as well.
No big deal, for sure.
