I am trying to use a button controller to mute/unmute one of my speakers (Google Mini)
I am able to setup a double tap to mute. Is there a method where I can use double tap to unmute? A toggle action instead of just the mute option?
Thanks.
Thanks.
You can setup the following rule in Rule Machine. I just tested it on my Google Home and it worked.
You’ll need to chose “Custom Attribute” to chose the If condition option “unmuted” on your Google Home as for some reason, they do not show in the list of music players...
Thanks! I will give it a try.
Works great!
Took a but to get it done (these IF THEN statements are not easy), but it works!
Yea, it takes a while to get use to how Rule Machine works, but after months of practice, it becomes easy...
