Sure can! Here's an example I just created to illustrate how you would do so.
I'll give it a try. Thanks.
Didn't work. Initially the lights turned on.
Tapped again and the Lights turned off and then right back on. After that, same effect when button is tapped. Off then back on...
It's always a good idea to post a screenshot like @ogiewon did so we can see exactly how you are configured. You can also look at your logs page to see if anything out of the ordinary shows up there...like if you see multiple button pushed events that could signal other issues. First things first though. Please post a screenshot of you BC setup.
I will. Thank you.
OMG..I think I took a stupid pill.. Toggle is working fine. I was adding a separate adjust dimming. Thanks for your assistance...
