Button controller ramp up down
i have some inovelli switches which are controlled by button controller. everything was working great in 2021 when i set them up and i just forgot about it. recently i noticed that certain commands no longer work specifically ramp up, ramp down. i used to control the LED strip with these commands when holding the switch. the button controller no longer has these defined only leaving me with on and off. is there a replacement for the ramp command? i want to ramp from 20% to 100% on a hold and vice versa. the only notes i have left from years ago follows;
Button 1 push - on 100%
Button 1 held - 0% (off)
Button 8 push - start ramp up
Button 8 held - start ramp down
Button 6 push - stop level change
Button 6 held - stop level change
i believe these were button mappings provided by inovelli.
