Hey All,
The other day my system started acting up - nothing that I had done that I’m aware of. I have 2 Inovelli switches that I use to arm/disarm HSM and to notify based on LED color the state of the system. I have a rule that looks for disarming of HSM and then changes the color on both switches to green. Several days again this stopped working. So I looked into my rule and saw that potentially there were some conditional issues causing the problem (though, again, it has worked flawlessly for 4 months). That seemed to fix it except it was lagging and took a bit longer than it should have on one LED (like 30 seconds or more - and today it didn’t even change).
So I opened up button controlled to look at how I have the button programmed, and I accidentally hit the “delay” toggle and ended up getting an instant error message. Now I cannot edit the button at all and the error message tells me to check the logs. I’ve taken a screen shot of the logs in the hopes that someone can help me. Thank you so much!!
Kindly,
Seth!
PS - I just tried rebooting the hub and I still cannot access the button controller. I also realized I cannot access any of the other buttons in that particular button controller app (in other words I can edit buttons for other controllers but not for this one).
PPS - I should also add that when I use my HSM dashboard to disarm the system the light changes on the switch immediately, so I don’t think it’s a zwave issue, but I could be wrong. Using the switch to turn off HSM does, in fact, disable it. It’s not making sense to me.
